Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > aftermarket speaker slightly hitting the window
      12-04-2023, 10:05 AM   #1
Jerezblack.m3
Jerezblack.m3's Avatar
149
Drives: BMW E92 M3
Hello, I was wondering if you guys could help me with a problem I'm having. I have an E92 HiFi system, and I bought an aftermarket speaker for my front doors – the Alpine S2-240C. While I managed to mount them properly, the window slightly touches the back of the speaker. The window does roll up and down, but you can see that the window pushes the speakers a little bit out. Is there any way I could create more clearance?
      12-04-2023, 11:52 AM   #2
ctuna
Drives: 325xi 06 wagon MT
There are a list of speakers that fit in the Audio build thread at the top of
the forum page in the sticky's . The coupe door is extra thin and the specs
are in there. If you bought one that is not a BMW compatible you could try
shimming it to the outside. .
https://www.e90post.com/forums/showthread.php?t=343673
There are many more BMW compatible speakers now but you have to be
aware the couple doors are extra thin,
BMW stereo types
http://www.e90post.com/forums/showthread.php?t=352586
http://www.e90post.com/forums/attach...2&d=1266451970
http://www.e90post.com/forums/attach...2&d=1260829447
http://www.e90post.com/forums/attach...1&d=1209780865
http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/
http://technicpnp.com/menuDiagrams/d...e90_92_93.html
http://www.musicarnw.com/page-2/
http://www.e90post.com/forums/attach...3&d=1169133185
http://www.e90post.com/forums/attach...1&d=1209780605
http://www.e90post.com/forums/showthread.php?t=641323
http://www.e90post.com/forums/attach...4&d=1278871872
http://www.e90post.com/forums/showthread.php?t=343673
https://www.bimmerfest.com/threads/e...n-752.1275694/
base system wiring pre/post 3/09
https://www.google.com/url?sa=t&rct=...tDpLJPcGkw_ui_
Base System Guide
http://www.e90post.com/forums/attach...5&d=1493273253
      01-18-2024, 02:53 AM   #3
streetpro
streetpro's Avatar
Czech_Republic
87
Drives: e92 335iA
I had the same issue with Eton 2 compo speakers, had to trim a bit of the plastic doorboard speaker surroundings/mounting plate to move it away/more inboard from the sliding window... also make sure that the foam water barrier is not torn... and sound deaden the door skin and doorboard... and the area under the tweeters location, surprisingly a lot of NVH/aero is coming through there...
"If everything seems under control, you're not going fast enough.” Mario Andretti
TiAgAu150.00
      02-29-2024, 01:59 AM   #4
Avetiso
Drives: 2008 E90 M
I think they only really fit the sedan. I just installed the same speakers on my car with no issues.
