04-09-2014, 11:02 AM | #1 |
Rep 104
Confirming 22" staggered offsets.
Let me know your thoughts. Using an offset calculator, comparing stock 20x10 and 20x11 to the following wheels.
22x9 and 22x11. Offsets on the 22's are +15 and +18 respectively. (Stock wheels are +40 and +35 (fronts and rears). Based on the calc I would stick out an additional 12 mm on the front and 17mm on the rears. I see a lot of you running 12 and 20mm spacers for a flush fitment. Correct me anywhere I'm wrong. Thanks. I think this setup would be a cost effective way to avoid going with custom forged wheels. I know forged are lighter and stronger, but I just finished "building" a GTR. I'm trying to stretch my dollar. Picking up a 2012 X6M this weekend. Cheers. |
04-09-2014, 12:10 PM | #3 | |
Rep 1,715
Drives: 2014 650xi Gran Coupe Msport
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
04-09-2014, 12:27 PM | #4 |
Rep 4,000
+1 Make sure to check the specs of the tires you are planning to get. Stated tire sizes are nominal, so you really need to look at the actual rolling diameter and revs per mile of each tire when going with a staggered setup. Tirerack usually has all this info readily available.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
04-09-2014, 01:45 PM | #5 |
Rep 104
I'd prefer 10's, but haven't found a staggered set up with 10's in the front. Planning on running 295 and 335's. I'm aware they recommend a 10" wide wheel for a 295, but 295 will work on a 9" without sidewall bulge.
Has anyone run an 11 wide on the front? High offset? I could run 11 wide +40 offset and be 13mm more "stick out". 22x11 all around. +18mm rears, +40mm fronts. 295 30 and 335 25 |
04-09-2014, 02:41 PM | #6 | |
Rep 1,715
04-09-2014, 04:35 PM | #8 |
Rep 1,715
Personally, I would look for a different wheel. 10.5 inch wheel is ideal for the 295/30/22 front tire. A 9 would be beyond bulged.
04-09-2014, 06:22 PM | #10 |
Rep 1,715
I'm a big fan of the staggered look myself, but it's your vehicle. I wouldn't put a 335 tire on the front. It is huge. Can't imagine it wouldn't rub.
04-09-2014, 08:19 PM | #12 |
Rep 1,715
04-10-2014, 03:46 PM | #13 |
Vanilla Gorrilla
31
Rep 610
In the correct offset the 11" up front would work, I haven't thought about running it myself so I haven't done the math on it.
I just swapped the summer tires on my diesel I should have taken a rear and bolted it to the front just to see how it fit.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
04-16-2014, 11:08 PM | #15 |
Vanilla Gorrilla
31
Rep 610
Last I heard they are on back order in North America
05-19-2014, 11:15 PM | #17 |
Rep 262
05-20-2014, 12:59 AM | #18 |
Rep 104
I'm assuming 265/295's? I couldn't allow myself to install a narrower tire than what it came with from the factory. You can put a 335 on an 11" wide, but 295 is def too wide for a 9".
05-20-2014, 02:45 PM | #19 |
Rep 262
That's definitely a choice wider tires do what for the SUV? I'm Running 295 in front and it gets caught in the grooves on our roads in Edmonton. And the ride is a bit rougher. Where the set up I did 265/315 the ride was amazing because I utilized a bit more sidewall. And does the rims look small no. They look big when I get to a computer I'll post the pictures
05-20-2014, 04:12 PM | #21 | |
Rep 4,000
A difference of only 0.25 - 0.50" in total rolling diameter can result in a 10-20 rev per mile difference, which will almost certainly shorten the life of your xDrive. It's also good to keep in mind that tire sizing is nominal - IE a 275 Pirelli summer tire is not necessarily equal to a 275 Pirelli winter tire. You most definitely need to look at the total diameter or revs per mile when installing non-OE tires.
05-20-2014, 07:30 PM | #22 | ||
Rep 1,715
