12-15-2022, 04:21 PM | #1 |
Rep 2
2011 BMW X5xdrive35i serpentine belt WONT FIT!!!
Good afternoon,
I had to replace the alternator on my 2011 X5 xdrive35i and while that was a nightmare...I have ran into an unexpected problem getting the belt back on. I purchased an OEM belt & the part number matches the same old one that I took off. However, when I try to lace it on (following the diagram below) it seems to be about an inch short. I have pulled and made sure that there are no kinks, bunches or hang ups of any kind. It will not fit in this orientation even if I do not install the idler tensioner and simply try to go straight from the large bottom left pulley in a straight line up to the alternator. HELP!!! If I use an alternative routing by going under the small center bottom pulley (rather than over it as the diagram shows) I can make it work. Is there something that I am missing? Does anyone have a diagram other than the one I am posting? If NO to both of the above questions is it alright for me to go under the center bottom pulley even though the ribbed side of the serpentine belt will therefore be against a flat pulley (generally a NO NO)? Thank you very much in advance for your help. Dave Last edited by Davethewave1; 12-15-2022 at 04:45 PM.. |
