09-14-2015, 09:40 AM | #1 |
Rep 2,086
Help reading OBD test
Hi Guys,
I run a self-test yesterday with OBD Torque app and this is the report. I guess I have a failed sensor? Mode $06 report generated by Torque for Android ================================================ Vehicle VIN: Not present Vehicle Manufacturer: Unknown Vehicle Calibration ID: Not present Test report: ------------------ MID:$01 TID:$83 - O2 Bank 1 Sensor 1 Max: 0.9 Min: 0 Test result value: 0.074 PASS ---- MID:$01 TID:$85 - O2 Bank 1 Sensor 1 Max: 0.9 Min: 0 Test result value: 0.043 PASS ---- MID:$02 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0.64001V PASS ---- MID:$02 TID:$02 Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0.64001V PASS ---- MID:$02 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0V PASS ---- MID:$02 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0.8257V PASS ---- MID:$02 TID:$86 - O2 Bank 1 Sensor 2 Max: 0.15128V Min: 0V Test result value: 0V PASS ---- MID:$02 TID:$91 - O2 Bank 1 Sensor 2 Max: 0.99991 Min: 0 Test result value: 0.04685 PASS ---- MID:$02 TID:$92 - O2 Bank 1 Sensor 2 Max: 65,534mV/s Min: 1,000mV/s Test result value: 11,374mV/s PASS ---- MID:$05 TID:$83 - O2 Bank 2 Sensor 1 Max: 0.9 Min: 0 Test result value: 0.271 PASS ---- MID:$05 TID:$85 - O2 Bank 2 Sensor 1 Max: 0.9 Min: 0 Test result value: 0.058 PASS ---- MID:$06 TID:$01 Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0.64001V PASS ---- MID:$06 TID:$02 Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0.64001V PASS ---- MID:$06 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0V PASS ---- MID:$06 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2 Max: 1.09934V Min: 0V Test result value: 0.83546V PASS ---- MID:$06 TID:$86 - O2 Bank 2 Sensor 2 Max: 0.15128V Min: 0V Test result value: 0V PASS ---- MID:$06 TID:$91 - O2 Bank 2 Sensor 2 Max: 0.99991 Min: 0 Test result value: 0.09373 PASS ---- MID:$06 TID:$92 - O2 Bank 2 Sensor 2 Max: 65,534mV/s Min: 1,000mV/s Test result value: 10,786mV/s PASS ---- MID:$10 TID:$1f - O2 Bank 4 Sensor 4 Max: 40,960 Min: 26,720 Test result value: 65,520 FAIL ---- MID:$21 TID:$81 - Catalyst Monitor Bank 1 Max: 0.92177 Min: 0 Test result value: 0.09373 PASS ---- MID:$22 TID:$81 - Catalyst Monitor Bank 2 Max: 0.92177 Min: 0 Test result value: 0.09373 PASS ---- MID:$35 TID:$84 - Max: 5° Min: 0° Test result value: 0.6° PASS ---- MID:$36 TID:$85 - Max: 5° Min: 0° Test result value: 0.2° PASS ---- MID:$37 TID:$84 - Max: 5° Min: 0° Test result value: 0.5° PASS ---- MID:$38 TID:$85 - Max: 5° Min: 0° Test result value: 0.2° PASS ---- MID:$3b TID:$81 - EVAP Monitor (0.090") Max: 255.99609mA Min: 0mA Test result value: 255.99609mA PASS ---- MID:$3b TID:$82 - EVAP Monitor (0.090") Max: 255.99609mA Min: 22.54297mA Test result value: 22.54297mA PASS ---- MID:$3c TID:$81 - EVAP Monitor (0.040") Max: 255.99609mA Min: 27.32422mA Test result value: 27.32812mA PASS ---- MID:$3d TID:$81 - EVAP Monitor (0.020") Max: 1.99882 Min: 0.17989 Test result value: 0.27258 PASS ---- MID:$3d TID:$82 - EVAP Monitor (0.020") Test incomplete or dependant test failed -- MID:$3d TID:$83 - EVAP Monitor (0.020") Test incomplete or dependant test failed -- MID:$41 TID:$85 - O2 Heater Monitor Bank 1 - Sensor 1 Max: 1,040°C Min: 695°C Test result value: 825.40002°C PASS ---- MID:$42 TID:$81 - O2 Heater Monitor Bank 1 - Sensor 2 Max: 5,000Ohm Min: 0Ohm Test result value: 112Ohm PASS ---- MID:$45 TID:$85 - O2 Heater Monitor Bank 2 - Sensor 1 Max: 1,040°C Min: 695°C Test result value: 824.79999°C PASS ---- MID:$46 TID:$81 - O2 Heater Monitor Bank 2 - Sensor 2 Max: 5,000Ohm Min: 0Ohm Test result value: 121Ohm PASS ---- MID:$70 TID:$1f - Max: 40,960 Min: 10,336 Test result value: 65,520 FAIL ---- MID:$91 TID:$70 - Max: 122.88% Min: -102.07999% Test result value: -0.13% PASS ---- MID:$a2 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a2 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a3 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data Max: 65,535Count Min: 0Count Test result value: 1Count PASS ---- MID:$a3 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS MID:$a4 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a4 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a5 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a5 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a6 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data Max: 65,535Count Min: 0Count Test result value: 1Count PASS ---- MID:$a6 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data Max: 65,535Count Min: 0Count Test result value: 1Count PASS ---- MID:$a7 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data Max: 65,535Count Min: 0Count Test result value: 1Count PASS ---- MID:$a7 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data Max: 65,535Count Min: 0Count Test result value: 1Count PASS ---- MID:$a8 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a8 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a9 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data Max: 65,535Count Min: 0Count Test result value: 1Count PASS ---- MID:$a9 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- End of report.
