Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Vendors Classifieds
      09-23-2014, 11:17 AM   #1
bmwretrofit
bmwretrofit's Avatar
>>> Bimmer Retrofit: NBT Retrofit in E70/E71 <<<
NBT NAVIGATION SYSTEM RETROFITS IN E-SERIES
NBT navigation system retrofits in E-series are becoming more and more popular! A lot of people who are considering CIC retrofit + Combox, are now opting for the NBT retrofit instead. If you are also debating between these retrofits, please consider the following advantages of the NBT navigation system:
• 200GB hard drive instead of 80GB drive (available in CIC)
• Combox built-in (bluetooth audio streaming, album art display, iPod/iPhone integration)
• Ability to stream video from USB in the armrest (CIC does not allow this)
• Sports Display (real-time power and torque meters)
• M-lap timer
• Faster processor (faster response speed)
• BMW Apps
• 3D maps
We offer either eNBT Retrofit Adapters SEPARATELY or we offer complete eNBT Retrofit Kits! Please contact us for pricing - info@bimmerretrofit.com
Our eNBT Retrofit Adapters give you:
  • ​Adaptation of NBT into E-series: ​You will be able to install NBT retrofit in E-series and retain all existing functionality*, including camera, PDC, night vision camera, HUD, etc.​
  • ​​iDrive Touch Controller Support
  • Activation of navigation
  • Activation of voice control
  • Activation of video in motion
  • RTTI Real Time Traffic Information
  • Supports all NBT hardware versions, including hardware version HW 21
  • iClick Technology
  • Supports Sports Display (Power and Torque)
  • BMW M-Lap Timer application support
  • Vehicle Live Data information display
  • Free PC Utility for eNBT Retrofit Adapter configuring and NBT head unit coding: Allows to code required NBT settings for proper operation in E-series vehicles
PC eNBT Coding Utility
Here are some pictures for you:
      09-23-2014, 11:18 AM   #2
bmwretrofit
Sport Display - Power and Torque
We are constantly improving all of our products, and we are proud to share with you two of our latest improvements for the Easy (eNBT) Retrofit Adapter.
1. Now all of the NBT head units are supported. This means that HW21 is no longer an issue! YES, HW21 is now supported and navigation will work perfectly fine in your E-series BMW with NBT powered by our eNBT Retrofit Adapter!
2. Our eNBT Retrofit Adapter now supports the Sports Display for NBT head unit in E-series! You can have Power and Torque displayed on the screen, just like it appears in F-series! It will show you real-time Torque and Power values of your engine.
More pictures to come!
Thank you for all your emails! We are replying to all email within 24hrs. If you do not get a reply within 48hrs, please try to contacting us again using a different email address, unfortunately some of your emails are blocked
      09-23-2014, 11:20 AM   #3
bmwretrofit
eNBT Coding Utility
eNBT Coding Utility
In the near future all of our eNBT Retrofit Adapters will come with a eNBT Coding Utility*.
The utility is already available for download free of charge (from our online store) and it will let you code required NBT settings for proper operation in E-series vehicles.
No special coding knowledge will be required for this: you will be able to select the desired options on your computer screen, and by doing so, will be able to correctly code the NBT to work in E-series.
* This eNBT Coding Utility is compatible with all of our eNBT Retrofit Adapters purchased from or from one of our resellers!
      10-14-2014, 06:53 PM   #4
bmwretrofit
October Sale until October 24th
October Sale is now over - post deleted
      12-11-2014, 02:01 PM   #5
bmwretrofit
If you are considering both CIC and NBT retrofits, and are unsure which retrofit is right for you, you will find the following thread helpful: http://www.xbimmers.com/forums/showt...9#post17064569
      03-30-2015, 12:26 PM   #6
bmwretrofit
Vehicle live data information on NBT/CIC display
New Extended Functionality of the eNBT Retrofit Adapter
Hello everyone!
eNBT Retrofit Adapter is built in a way that allows us to improve its functionality over time.
Recently we have successfully added some interesting and important features to the eNBT Retrofit Adapter.
One of these is Live Vehicle Data on NBT display coming from engine, powertrain and other modules.
This may be very useful for all those who want to keep their hand on the vehicle's pulse
Currently we are also releasing a new version of the CIC retrofit adapter for CIC head units which will also support this Live Data output on CIC display.
Below are some screen showing the new functionality.
The screen shots are taken from NBT retrofit installed in E71, using our eNBT Retrofit Adapter. Pictures from CIC will follow soon.
Please also check out the video below:
      10-14-2015, 11:45 AM   #7
bmwretrofit
eNBT Retrofit Adapter with Dynamic Lines, Climate controls and Bluetooth
We now offer a new version of eNBT Retrofit Adapter for E-series.
This new version offers additional features:
  • Supports Dynamic Lines for a rear-view camera
  • Colored climate controls menu
  • Bluetooth radio built in
  • Live vehicle data from engine, powertrain and other module (speed, temperatures, torque, G-Sensor and more) on NBT display
You will be able to connect a qualified rear-view camera to the eNBT Retrofit Adapter and enjoy OEM-style rear-view camera with dynamic guide lines. As you turn the steering wheel, the lines will move on the display.
This option is very useful for E6x and E7x vehicles, as this special menu will let you see current climate settings on the display, but can also be used in other models of BMW, such as E90.
This special feature will let you use your Android* and iPhone to see various parameters of your vehicle's "health" visually. You will see various graphs, showing things like: RPM, speed, torque, power, etc.
Also, this special feature will let you do all the same settings configurations as the eNBT PC Utility, i.e. allows to code required NBT settings for proper operation of NBT in E-series BMWs.
Live vehicle data
This special menu lets you see live vehicle data from engine, powertrain and other module (speed, temperatures, torque, G-Sensor and more) on NBT display to be in control of your vehicle's performance.
For official product page, please click here.
For all available eNBT Retrofit Adapters, please click here.
Please check out the latest video for a demonstration.
*Planned for 2016
      03-15-2016, 03:32 PM   #8
bmwretrofit
Group Buy - Ends on March 25th!
Spring is the season of new beginnings and new life. Why not give your BMW dealer a new life with one of our Bimmer Retrofits?
This is your chance to get your Bimmer Retrofit at a fraction of the price, but at the quality that you can trust!
Please contact us for pricing information, since our website does NOT show all available DEALS: info@bimmerretrofit.com
*Please make sure you include the VIN of your vehicle for faster turn-around time!
      09-07-2016, 02:57 AM   #9
bmwretrofit
NBT EVO ID6 retrofit in E-series
NBT EVO ID6 is latest navigation system from BMW, available from factory in G-series and select F-series BMW. NBT EVO ID6 is definitely the best development of BMW yet... and this is the best integration of NBT EVO retrofit in E-series!
We provide everything needed to install NBT EVO retrofit in E-series BMWs. Our eNBT Retrofit Adapters fully support NBT EVO functionality in E-series.
Take a look at our eNBT Retrofit Adapters or contact us for a quote (make sure you provide the VIN of your vehicle).
Watch our video for more information on this retrofit:
      05-16-2018, 01:17 AM   #10
bmwretrofit
Contact us for a custom quote today: info@bimmerretrofit.com
      06-06-2018, 12:37 PM   #11
bmwretrofit
      05-14-2019, 12:45 AM   #12
bmwretrofit
      12-24-2019, 12:26 AM   #13
bmwretrofit
Merry Christmas and Happy New Year!
20% Discount Until January 5th!
Get:
No coupon codes required.
Offer ends on January 5th at 23:59 PST. Quantities are limited. ACT NOW!
For any questions or custom quotes, please contact us by email: info@bimmerretrofit.com. Don't forget to provide the VIN of your car!
You can now check the VIN of your BMW to see all compatible retrofits: https://bimmer.vin
