02-06-2021, 08:07 AM | #45 |
Rep 357
Remember, any damage to the soft aluminum block will not seal the cover to the block correctly. Especially the water jackets. That was my only concern, having coolant dripping into oil would be a disaster. The gaskets are metal or aluminum. With very limited space, it tough to have any prying tools.
With heads still on and cam gears removed, there’s plenty of space. |
03-04-2021, 07:35 AM | #46 | |
Rep 2
Hi. New to this forum. Anyway, I am working on my n63 as we speak. My initial plan was to just replace all of the coolant and oil lines around the turbos and also replace all of my valve stem seals.
Somehow I ended up replacing the timing chains as well. Haha. It's never ending! There is a way to remove the lower timing cover without taking heads off. It definitely helps to remove everything in front of the car (radiator, ac condenser, etc.) so you can just sit in front of it! I removed the crankshaft seal to give me room for a 3 jaw puller to sit in. put the crank bolt back on so you're not having to thread on the actual crankshaft. When you put that 3 jaw puller, it is really easy to get that lower timing off. Quote:
TTV8M126.00 |
11-05-2021, 07:10 PM | #47 |
Rep 21
In desperate help on a 550i woth n63. Just rebuilt engine and now it wont start and has codes for cam timing. I have checked it several times and it seems fine??
11-06-2021, 03:24 PM | #49 |
Rep 21
Just rebuilt an n63 from a 2011 550i and it will not even try to start, just cranks. Has spark, but not getting fuel. I get timing codes for all 4 cams, I have removed the valve covers and verified timing with the timing tool set and it sets on the cams perfectly flat. I did replace the crankshaft is it possible that it is different? I am out of options any help appreciated.
11-06-2021, 03:28 PM | #50 |
Rep 21
I bought it with a spun rod bearing so bought a complete crankshaft kit with all bearings, new timing chains, guides, tensioners, valve seals and many other parts. It will only crank which is smooth and steady but never fires. It did fire once with starter fluid so it has spark but no fuel. New plugs are bone dry, injectors not firing for sure. I get cam codes for all 4 out of range. I tested the crankshaft position sensor and it seems to be working but have a new one ordered to try. i did not compare my old crank to the new one, lesson learned. Is there different ones for this engine that could have the flywheel off? Thanks everyone!
11-06-2021, 05:37 PM | #51 | |
Rep 1,564
11-06-2021, 05:46 PM | #52 |
Rep 21
Thank you, i used aftermarket kit. Locked balancer to the timing cover using the to and pin and it was covering the mark on the balancer. Placed the cam gears on with red being on exhaust and black on intake. Usi g new bolts put them hand tight and rotated the gears ccw making sure they were locked and then tightened to 30nm. Removed the cam locking plates rotated the engine many times and it would end up perfect with plates sitting flat. Then removed the pretention tool and unstalled the new tentioners and pulled the pins. Then put the plates back on holding the cams and tightened the center gear bolts 90 degree. Did same for both heads and finished everything up reinstalling the engine and tried starting the car. Cranks but wont fire. Remived valve covers again and reinstalled timing kit and everything sat perfect on both heads. Im lost...
11-06-2021, 07:22 PM | #53 | |
Rep 1,564
11-06-2021, 07:36 PM | #54 |
Rep 21
Yes did additional 90 degree on bolts, and you are correct about cams. I labeled them a b c d. Intake on bank 1 only works in its spot as it operates the vacuum pump. Im starting to think i got the wrong crank... bought a kit from a shop that repairs and sells with all new bearings. Going to try and check compression and see what that shows but afraid i will never be able to set timing if flywheel is off
11-06-2021, 09:04 PM | #56 |
Rep 21
No, i didnt compare the part numbers before returning the core...lesson learned. It installed perfectly and i have gone over the harness sevral times and all seems fine. Tested the cam and crank sensors today, all have 12v, and, and 5 volts. If i trick the sensors with metal they drop signal voltage to 0. Going to replace crank sensor just because but with all those codes im afraid the flywheel is not timing it correctly as far as the computer is concerned
11-06-2021, 09:50 PM | #57 |
Rep 1,564
Sounds like your doing everything right. After you replace your crank sensor, be sure to reset all engine adaptations. Also have you monitored your fuel rail pressure? It should be around 1200-1600psi when cranking if memory serves.
1jwhite0.00 |
11-06-2021, 10:34 PM | #58 |
Rep 21
Yes it is about 1700 psi. I have an autel maxi sys but not seeing anything about resetting adaptations. Might need itsa for that? It was running before rebuild... so frustrating. Could i possibly have the crank 360 degrees out when i set the cams?
11-06-2021, 11:45 PM | #59 |
Rep 1,564
It's been a few years since I did mine so I'm a little fuzzy on th details but when you drop the alignment pin in on the crank, cylinder one is supposed to be at TDC or close to it, I would check your at TDC on cylinder 1 when your setting cam timing. I'm pretty sure it's TDC on tb compression stroke so if your 360 out then the exhaust valves will just have closed so watch them when rotating. Double check everything I said though if TDC is on compression stroke for the n63, as I mentioned Its been a few years.
11-07-2021, 05:56 AM | #60 | |
Rep 45
When I was replacing my valve stem seals, after taking out timing chains from cam sprockets, I could rotate each camshaft freely 360 degrees with spanner. So it means that valves were opening but not hitting any pistons thus no piston was at TDC. I belive piston 1 it's like 150 degrees BTDC when setting up timing. |
11-07-2021, 06:08 AM | #61 | |
Rep 45
Was the pulley correctly placed on crankshaft ? Was flywheel placed correctly ? Most engines have some pin or something to prevent incorrect position during instalation. Are you sure camshafts are in correct position ? I'm not 100 % sure, but it may be possible to put them on 180 degrees out because of the way the timing tools are made. In instructions there's pictures of cam lobes positions in correct timing. |
11-07-2021, 08:26 AM | #62 |
Rep 21
Yes, the timing tool is lined up with the mark on the balancer which is aligned correctly by the keyway on the crank. Your right the no piston is at tdc during timing allowing free rotation. I have the cams facing the way they describe with the 3 flat sides basically up and lobes pointing as they describe ensuring cam placement...
11-07-2021, 08:46 AM | #64 | |
Rep 1,564
11-07-2021, 09:01 AM | #65 |
Rep 21
11-07-2021, 09:03 AM | #66 | |
Rep 1,564
Then next you should a compression or leak down test. If those all check out then ignition/fuel is next on list. Btw, wiring hardness for the injectors and coils that bolts to engine covers gets it's ground point from those 10mm bolts that bolts it to the valve covers. Just a heads up if you make the mistake of not using every bolt to bolt down the wiring harness because you are test firing the engine. |
