08-29-2016, 10:53 AM | #23 |
IG @bmwF9xG80
3817
Rep 7,595
Gatoferoz25 get that beast tuned
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
08-29-2016, 01:36 PM | #24 | |
BeastM3r
1286
Rep 1,657
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
08-29-2016, 08:01 PM | #27 |
IG @bmwF9xG80
3817
Rep 7,595
60-130 6.5s X4M
08-30-2016, 12:18 AM | #29 |
Rep 2,062
Since I've got a tablet installed, is there a way to run a cable from the JB4 into the tablet and avoid an $150 added on piece?
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
08-30-2016, 12:30 AM | #30 |
Rep 1,174
08-30-2016, 03:31 AM | #31 |
*May contain nuts
193
Rep 286
11-09-2016, 04:17 AM | #33 |
*May contain nuts
193
Rep 286
12-19-2016, 11:04 AM | #34 |
Rep 104
Quick update. I finally installed my JB4 and ran it for one day only. The next day my battery died (original one that went 5 years...not bad) and I had it brought to the dealer to install a new one. I took out the JB4 first (took 15min) but decided to move on to another car so I never put the JB4 back in. I have to say though the JB4 brought a smile to my face just as much as the Velos stage 2 did. Surprised me as I didn't think it would be too noticeable. For me it was very obvious the car had more power. I didn't get around to having any adjustments made like we are supposed to after mapping it or anything but ran through the 4 modes of power via the steering wheel controls on the fly (a nice feature). I bought the bluetooth and app and found that pretty cool. Thanks to whoever said I should get it. It's super easy to map and email results right from the app. Sorry this isn't too helpful. I definitely would put it back in if keeping the car. If anyone is interested I'll sell the JB4.
12-20-2016, 08:37 AM | #35 | |
Rep 286
12-27-2016, 01:11 AM | #36 | |
Rep 1,174
Sorry to hear.. 17psi is fairly aggressive. Anything beyond that requires race fuel(ms109) for sufficient fueling. These cars run 8psi stock. You should scoop up the JB4 from the member above and get it installed, 110% worth it |
12-27-2016, 06:11 AM | #37 | |
Rep 286
I guess the stock turbos are maxed out pretty much at 18-19 PSI like Terry said in the thread about tuning your truck. I'll get the JB4 regardless for the features and the ability to adjust the boost since I have a set of PURE stage one turbos installed but haven't been able to push them with the out of the box tunes available. Thanks again for sharing the info. |
02-02-2017, 02:11 AM | #39 |
Rep 2,062
Bought this from Tailwinds, just haven't installed it yet. Sick335, are those three maps he loaded on your JB4 pretty standard? I'm just curious about what to do after installing this seeing as I've already got a stage 2 tune. I've written Halim, my tuner, via WhatsApp but he's on the other side of the country so there's a delay. I just don't wanna have the wrong map on, got WOT and cook my motor the first time out.
02-10-2017, 06:29 PM | #40 | |
Tanzanite Blue II X5M Pilot
1059
Rep 2,040
Drives: M3, M4, X3 M40i, X5M
03-20-2017, 12:28 PM | #41 | |
Rep 286
As for out of the box, the Stage 1 Pure turbos did not make any noticeable difference with the stock tune or with the AA stage 2 tune. I think Stage 1 is pretty worthless on these. The our turbos are basically the same as the N63 but with a larger compressor. The turbine is the same size. The Pure stage 1 takes the compressor and makes it larger again but leaves the turbine the same size. You can see with the stock turbos the power falls off pretty quickly. It still does the same with the stage 1's. The turbine is just too small and the back pressure is killing any flow gains from the compressor up top. I did these because Pure will upgrade stage 1's to Stage 2's for the price difference and the Stage 2's weren't out at the time. So I recommend if you're getting turbo upgrades do not waste your time on these and go with the stage 2's. Of course they are 5k so now you are getting deep into the gains vs cost calculation. No one has made much power beyond the tune and DP point and talked about it at least on the E70/71 platform. Not to mention what the drivetrain can take. I stand behind if you want to go faster then the tune and DP point on this platform just trade it in for the new 2014+ X5/X6M. The S63TU is a much better motor to start with, not to mention the rest of the truck. |
protecon193.00 |
03-21-2017, 02:42 AM | #42 |
Rep 2,062
This still begs the question...was AA's tune the same canned tune for anyone vs being custom tuned for those turbos? This isn't a new thing yet easily forgotten that just about EVERY substantial mod like that requires a custom tune to actually utilize it fully. I've yet to see a single tuner for the S63 actually say they've got a tune that is anything more than stage 1 (stock car, just a little quicker) and stage 2 (catless downpipes, maybe mufflers). Until I see a tuner say a special stage for custom turbos like on the N54, I think this is only telling half the story as to why it doesn't feel any different.
If you want to go faster than tune and DP, I say go JB4 first before going turbos. The power from stock to flash was a jump, the power from flashed to stacked with JB4 was a leap.
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 04-09-2017 at 09:00 PM.. |
03-25-2017, 06:20 AM | #43 | |
Rep 286
I ran the standard stage 2 tune. All the tuners have the same tune that was made by the same person. They are just vendors not tuners. Nobody has a custom tune for the S63 non-TU motor. The market is to small and there are no more gains to be had beyond the stage two with the stock turbo. If you read the thread where Burger Motor Sports tuned the truck that started this thread you will see extra boost beyond the canned stage 2 tune level on the stock turbos does nothing. Completely untrue. Stacking the JB4 with a tune on this platform is a waste of money. That is only effective if the tunes can not reach the max effective boost levels for the turbo/motor. Not the case at all with our motor. This is valid with the S63TU motor, not ours. Last edited by Myaddiction; 03-25-2017 at 10:23 AM.. |
03-31-2017, 02:11 AM | #44 | |
Rep 51
Myaddiction,
I have Velos Stage 2 tuning on my 2010 X6 5.0. I was thinking on getting the JB4. Are you saying that both of these are the same? Quote:
Tags |
jb4, power, racecar, tune, x6m |
